standard exhausts
jodydid
standard exhausts
Thu Jun 27, 2013 6:26 pm » Post: #1 » Download Post
i have a spare set of std exhausts i was thinking about cutting them in half and seeing what was inside removing it then re welding them back together has anyone else had a set apart?
i did this years ago on a dt 125 front pipe and had good results lighter system and better mid range power
just a thought thanks jody
Fri Jun 28, 2013 6:57 am » Post: #2 » Download Post
I met a guy a few years ago that did it. He seemed to think it worked out ok.
nxrsr20
Fri Jun 28, 2013 8:22 am » Post: #3 » Download Post
If you do it, take some photos please!
stefanos-MC28
Fri Jun 28, 2013 11:23 am » Post: #4 » Download Post
You can see what is inside at an MC21 chamber here at 3:22sec http://www.youtube.com/watch?v=zl2nBXXsPU8
Do not expect to find anything to mod like the DT125,i dont think it is worth the effort.
I had read here at the forum that MC18 has better chambers from the MC21.
As i know the restriction is in the silencer.
Only MC28 has a washer restriction on the chambers.
Check here the differences on a MC18 (R5K-R6K) between the pipes. http://www.nsr-world.com/tuning/250-tuning/ignition/
Owner of : Honda NSR250 MC28 95sp colours / Honda NSR250 MC18 R6K SP / Honda RS250 NF5 89 in boxes Sad / Honda C50 12V cub / Honda C50 12V super cub Japanese version /Yamaha XT600 89 benetton
stuntpea
Thu Mar 27, 2014 10:39 pm » Post: #5 » Download Post
Hi guys,
I've got an MC28 I'm rebuilding and when I took the pipes off I measured across the hole which butts up to the barrel. It was something like 32mm or something, I forget now. Then I measures the opening to the carb and it was something like 34mm.
Is the metal at the head of the exhaust the restriction? So can I get like a grinder attachment on my drill and grind it out a couple of mm to get more flow?
I have a lathe and I could use a boring head to ream the hole out but the pipes are such a wobbly shape I don't think I'll be able to hold it squarely in the lathe.
Here's a skanky picture of the pipe hole
I've since de coked the pipes with a heat gun. It melted the heat gun but nice coke free pipes.
Rich
