NSR250 heated grips
NSR250 heated grips
Thu Nov 21, 2013 10:52 am » Post: #1 » Download Post
I see that a popular auction site has some heat grips listed.
I was thinking of getting a set along with a top box, Scott oiler and a pillion seat back rest
Thu Nov 21, 2013 8:56 pm » Post: #2 » Download Post
They'd go well with crash bars and auxiliary daylight running lights I think.
Dannyvirk
Fri Nov 22, 2013 12:50 am » Post: #3 » Download Post
heya
What about: Highway pegs, with dual forward controls, top triple clamp with 8 inch riser and the full monkey ape hangers manufactured from chain links welded together and chromed. Then cut, rake the frame and fit a 20 inch extended chrome springer front end sans brakes, a sissy bar and twin slash cut drag pipes.
Paint job options: Matt black or an american flag with 7/11 and M.I.A motifs or my personal favourite the everythings flaming with flaming: skulls/naked women/money/jesus/mum/flames/John 4:16/Paul Shaffer
cheers
mydogtaz
Fri Nov 22, 2013 6:10 am » Post: #4 » Download Post
Aaaaaaaaaaaaargh...............The stuff of nightmares................. Evil or Very Mad
gepe
Fri Nov 22, 2013 7:53 pm » Post: #5 » Download Post
7/11: wasn't that 9/11? Wink
TuckerBag
Fri Nov 22, 2013 9:33 pm » Post: #6 » Download Post
I guess for regular use during the winter months I could go with:
Handlebar mitts
Scott Oiler
Slightly raised 'bars
But that's about it.
Otherwise, I'd just get a four stroke.
I'm sorry but the thought of a Top Box on a sports oriented 2-stroke,... well, c'mon now.
Dannyvirk
Mon Nov 25, 2013 12:48 am » Post: #7 » Download Post
Heya
I made up a set of highway pegs for my FZR400RR, there was an engine mounting point on the front of the engine that was unused, i think because they went from a perimeter to a beam frame style, so this mounting point was redundant. The bike also had no lower fairings.
I made the pegs from 6 inches of 20mm diameter rebar with an 8mm bolt of the appropriate lenght welded to the end, times two.
They made the bike a far more rideable proposition on trips longer then 20km.
This is where it gets weird though, imagen piling into a corner leaning over hard with your feet inline with your hands horozontal position, truly a strange sensation after a life time of conventional sports bikes.
cheers
kan3
Mon Nov 25, 2013 1:04 am » Post: #8 » Download Post
I don't think the charging system would even be able to handle the extra 20-40 watts the grips would need. Unless I measured wrong with my multimeter, it just produces enough wattage to support the system and lights at normal cruising rpm.
Dannyvirk
Mon Nov 25, 2013 1:13 am » Post: #9 » Download Post
heya
20 to 40 watts is less then the draw for the headlight.
cheers
kan3
Mon Nov 25, 2013 1:25 am » Post: #10 » Download Post
Dannyvirk wrote:heya
cheers
Ya, but would someone want to turn the headlight off every time they were to turn the grips on?
Dannyvirk
Tue Nov 26, 2013 8:34 am » Post: #11 » Download Post
Heya
Yeah, i mentioned that as i added an extra headlight plug on my MC - 18 loom because the MC - 21 chassis it's in has the extra headlight. And i failed to consider if the extra bulb might create problems.
Tue Nov 26, 2013 10:05 am » Post: #12 » Download Post
This wasn't a serious thread!
However, with more and more LED lights on the market, it would be a good idea to switch to one of the low current draw bulbs if you are going to fit heated grips. Wink
