MC16 Crankshaft seal
weeheavy
Sat Sep 27, 2014 1:51 am » Post: #1 » Download Post
Having a bit of a hard time finding part # 91203-KV3-003. I live in Canada and can source the other side through my dealer but not having any luck with the other. Thank you for any help.
Sat Sep 27, 2014 10:23 pm » Post: #2 » Download Post
Although it's not the correct part, you can get away with using an MC21/28 seal. It just sits "recessed" in the cases, and not flush like the MC16 seal.
91203-KV3-831 is the part number. It's just 8mm wide, instead of 10mm.
andyburton1977
Sat Oct 04, 2014 10:46 am » Post: #3 » Download Post
Do all NSR 250 crank cases have the same dimensions regarding the crank seal housing orifices ?
Can the crank seal 91203-KV3-831 also be used successfully in the mc18 r5k ?
cheers
weeheavy
Sun Oct 05, 2014 1:50 am » Post: #4 » Download Post
Thanks very much for the info.
