If you really need bigger discs, in my opinion you would be better off going for 296mm, as you will find a lot of original Honda discs that bolt straight up to the NSR wheel, have the correct swept area, and the correct offset. _________________ Andy.
Hi Andy,sorry, I should have explained my request. I looking at doing a fork upgrade and the Forks are setup for a 310mm rotor. Any ideas on what might fit? _________________ "If your not first, your last!" Ricky Bobby
the nsr takes the same rim as the cbr250rr, which has the same stud pattern as the cbr900, vtr1000f, and a few others. I have those disks on mine but from memory I think they are 290mm
297mm _________________ Andy.
Thanks guys....looks like he ISR rotors that Andy mentioned would be my best bet! Thanks for all the advise. _________________ "If your not first, your last!" Ricky Bobby
