Probably unlikely, but can MC21 SP Fork Caps go on Non-SP?
KICKER
Wed Jan 21, 2015 2:56 am » Post: #1 » Download Post
So basically I'm building my fake SP model. So far the only thing about it is the SP/SE motor. So in my efforts to continue the fake SP stuff, I was wondering if you can put SP fork caps on the normal forks? SP forks are a bit pricey and out of the question so this is just a quick for-looks thing. Plus, if I'm honest, would rather get RVF400 forks. But fork caps are relatively cheap and would improve the bike I think. Will they ft?
Wed Jan 21, 2015 8:55 pm » Post: #2 » Download Post
Yes you can.
KICKER
Sat Jan 31, 2015 11:09 am » Post: #3 » Download Post
StephenRC45 wrote:Yes you can.
Thanks for that Stephen. The parts bill seems to be ever increasing... Also, the other reason I want SP caps is I bought Tyga preload adjusters without really thinking and went to install them... and a no-go.
Sat Jan 31, 2015 11:12 am » Post: #4 » Download Post
They will fit but the damper adjuster won't do anything of course. Found a number of SP forks that are in fact just R's with tops.
DUX
Banned
forks off
Sat Jan 31, 2015 1:06 pm » Post: #5 » Download Post
The Heretic here Laughing , you read a lot now about fork cartridges and how good they are, I have an SP can you fit cartridges in them.
Where did you find the silly figures on your post.
D.
KICKER
Sun Feb 01, 2015 2:57 am » Post: #6 » Download Post
StephenRC45 wrote:They will fit but the damper adjuster won't do anything of course. Found a number of SP forks that are in fact just R's with tops.
Yeah, I wonder about that last night. Hmm, I'll see what options I have. The problem is my MC21 forks are bent (not a huge amount, but still bent enough for me to want new ones). So getting new forks I either need to rebuild my R fork (with new stanchions), by used R forks, buy SP forks, buy RVF forks (easiest USDs) or mod other USDs to fit. I guess whichever is the cheapest will do at this point. I might just use my MC18 forks for now since they're in good condition.
Sun Feb 01, 2015 5:01 am » Post: #7 » Download Post
If they slightly bent, but not creased [at the lower triple], then there should be every chance they can be straightened without the expense of re-chroming.
Straightening is probably as cheap (or close to it) as sourcing a replacement set of R forks, I expect.
DUX
Banned
stephenrc45
Sun Feb 01, 2015 10:01 am » Post: #8 » Download Post
DUX wrote:The Heretic here Laughing , you read a lot now about fork cartridges and how good they are, I have an SP can you fit cartridges in them.
D.
Yuri
Sun Feb 01, 2015 11:38 am » Post: #9 » Download Post
Is there other fast ways to see if it is SP forks ? If the fork cap has been changed
I am saving to buy a mc28sp .....
Sun Feb 01, 2015 5:02 pm » Post: #10 » Download Post
You'd need to be pretty dedicated to swap fork caps on the MC28, as the SP caps are different again to the SE. Not saying it couldn't happen, but it would be very unlikely.
Nothing's ever going to save you from a "fake" SP except possibly a Honda engine/VIN certification before you buy it. Even then, there's no guarantee it has all the original parts on it.
Yuri
Mon Feb 02, 2015 5:13 pm » Post: #11 » Download Post
Andy wrote:You'd need to be pretty dedicated to swap fork caps on the MC28, as the SP caps are different again to the SE. Not saying it couldn't happen, but it would be very unlikely.
I am a South African so a bit paranoid ....
Mon Feb 02, 2015 9:12 pm » Post: #12 » Download Post
And not the first! Laughing
KICKER
Thu Feb 05, 2015 1:13 am » Post: #13 » Download Post
Unluckily for me there is a crease so the stanchions need replacing. The MC21 looked like it had been into a ditch so I was expecting bent forks. Ideally I'd put a set of RVF400 forks on (with Tyga triples) but in Australia the RVF400 is actually an expensive bike because it's one of (if not the) fastest learner bike you can get. So the next option is to find one that's been wrecked and most of the time the forks are damaged. But I keep an eye out. If any other suitable forks come available (RS forks.. maybe, I wish) I'll look into it but for now the MC18 forks will have to do!
Thu Feb 05, 2015 2:44 am » Post: #14 » Download Post
Hmmm... building a "fake SP", and thinking of SE/SP caps on R forks, but considering NC35 or even RS forks? Am I missing something?
Why don't you just source SE forks? Easy enough to find, cheaper and easier than an RVF400 conversion, and HUGELY cheaper and easier than fitting NF/NX5 RS250 forks.
For what you'd spend on USD forks, you could probably finish the bike to real SP spec... and for what you'd need to spend on RS forks these days, professionally repaint it too! Really, have you even priced up an NC35 conversion? You need forks, triples, calipers, discs... new head bearings, seals, brake lines, fender, etc., etc., etc.
KICKER
Fri Feb 06, 2015 1:07 am » Post: #15 » Download Post
Well, I haven't done the sums but the easiest place to get forks from would be Japan... and the price difference is negligible between NSR and RVF (very briefly had a look on yahoo Auctions). Unfortunately shipping is always the killer. And the Sp model thing, yeah, not 100%. The cheapest thing would to be to just import one but I'm just putting this one together essentially for free.
