Oil coming from places it shouldn't
aky141
Fri Feb 20, 2015 1:02 am » Post: #1 » Download Post
Hi all,
I've got oil coming from a hose which leads to just above where the reed valves are, It has been sitting for 8 months and has only just been started, it looks like the 2 stroke oil i run,
*Bike is a MC21SE*
Edit 2
Just pulled gearbox filler plug out
Gearbox full off two stroke oil,
I'd Guess a Seal in the pump, Gonna check out parts diagram now
Fri Feb 20, 2015 10:36 am » Post: #2 » Download Post
Yep! That's your culprit!
A good clean [degrease] with brake cleaner, and a [very] little Threebond between the seal and the housing, and you'll be good to go.
aky141
Sat Feb 21, 2015 8:54 am » Post: #3 » Download Post
Is it possible to buy another? andy, might be worth it as seal is probs 20+ years old
Sat Feb 21, 2015 10:10 pm » Post: #4 » Download Post
Not particularly easily. It's not available from Honda, and it's typically an awkward size.
They rarely cause problems, other than slipping down the drive shaft once in a blue moon. I've never, in 20 years, known the same seal to need "fixing" twice.
foxmcscrooge
1996 Honda MC28 SE
Mon Feb 23, 2015 10:41 am » Post: #5 » Download Post
If what Andy said fails I have a few spare seals Aky. When I rebuilt my engine recently I used the 3 bond method with a new seal of the same dimensions as the Honda one. No sign of any leaking yet. Let me know and I can send you one. PM me on 2fifty.
