g'day, probably a stupid question ... but how do you remove the rear spring/shock assembly? bike is down to chassis (everything off except wheels, swingarm, ) have a mc21.. have removed top mount nut and bolt and also bottom mount nut but not sure if i remove bolt what will happen? under pressure or holds up rear end etc...
thanks is advance
rob
