Exhaust sucking air.
bandit_7
Sat Jan 08, 2011 12:41 pm » Post: #1 » Download Post
Well I'm stumped. I have just put a used bottom end on my mc21 as the last one had a worn crank, seals and bearings. Now for some strange reason the lower cylinder is sucking air into the exhaust while idling. It has a little putt every now and then with a bit of smoke coming out but that's it. When I give it a little throttle around 2500rpm it gets a bit better but the exhaust gas seems colder than the top cylinder. At around 5000rpm it heats right up and appears to be good.
The top cylinder is running great, no complaints at all.
I have cleaned the carbies, rebuilt the reed cages, swapped the coils over and had a good general look over to eventually find nothing out of the ordinary.
Any advice or idea would be great as I can't think of a single thing to try now. Don't hold back, I'm willing to try anything.
Chester362
Sat Jan 08, 2011 1:04 pm » Post: #2 » Download Post
First place I would start is making sure there are no air leaks, etc.
Then clean/blow out the carbs.
Then balance the carbs.
Then check spark plugs/ignition coils,pick-ups,etc.
bandit_7
Sun Jan 09, 2011 9:44 am » Post: #3 » Download Post
Carbies have already been cleaned and balanced, ignition checked and ok. I have sprayed aero-start all over the engine whilst running and that had no effect aswell. All air solenoid assembly has been cleaned and checked.
Today I removed the airbox and ran the bike for a few minutes just to see if there was anything out of the ordinary. I did notice a small amount of fuel being expelled out the carby throat on the lower cylinder while giving a little throttle. At idle there was only a sucking effect. At this point the exhaust is still sucking.
It would appear that there is only one place for the air/fuel mixture and air from the exhaust to be going. I guess it's time to break out the old leak down tester.
You would think the cylinders would work as a team but NO, one has to get greedy!!!
Middo
Sun Jan 09, 2011 9:03 pm » Post: #4 » Download Post
Sounds like the same thing that my bike is doing. Keep us all updated of your progress. Good luck!
bandit_7
Tue Jan 11, 2011 10:08 am » Post: #5 » Download Post
Hooray!!!
I get to pull another motor apart. Who likes riding bikes anyway. Rolling Eyes
The center crank seal almost holds 2 psi for 1.57 seconds.
All 3 crank seals failed miserably but the center one is by far the worst. It is passing air from bottom to top cylinder way faster than top to bottom.
I guess that's what you get when you buy a bottom end from the worlds most popular auction site. Evil or Very Mad Evil or Very Mad Evil or Very Mad
Almost time to give up on the bike and concentrate on the rx4.
bandit_7
Tue Jan 11, 2011 10:15 am » Post: #6 » Download Post
It was advertised as "mc21 bottom end with good crank seals"!!!
Not very accurate.
{.bLanK}GoD
Wed Jan 12, 2011 12:10 am » Post: #7 » Download Post
Keep note the center crank seal will leak air from right to left (bottom to top cyl) within hours after the engine has been shut down. This is normal. With the engine running, the 2t oil will seal it completely.
bandit_7
Wed Jan 12, 2011 5:11 am » Post: #8 » Download Post
All primary chEcks were done with the engine running. Seals are gone ( all 3). Please excuse the short posts as seq where I live are experiencing the worst floods in 35 years. Smile
Sinking Andy
Thu Jan 13, 2011 12:46 am » Post: #9 » Download Post
Post deleted for shorthand TXT.
shmokica
1990 Honda NSR250 MC21
Thu Jan 13, 2011 9:36 am » Post: #10 » Download Post
bandit_7 wrote:It was advertised as "mc21 bottom end with good crank seals"!!!
Not very accurate.
Bugger, glad I didn't win it now, I think I was the second highest bidder.
bandit_7
Thu Jan 13, 2011 8:12 pm » Post: #11 » Download Post
A couple more sets of red traffic lights and I wouldn't have made it home to bid at all!!! By the time I got the computer on there was about 5 minutes left.
