vacuum connector needed for MC21
drank5
Tue Jan 18, 2011 6:38 pm » Post: #1 » Download Post
Looking for the 1 1/2" x 1 1/2" cross hair or "+" looking piece that sits in the middle of the carbs. Mine broke and epoxy and super glue didn't hold.
Thanks-
dd
www.raresportbikesforsale.com
drank5
Thu Jan 20, 2011 3:43 pm » Post: #2 » Download Post
C'mon guys.. almost 60 views and no one has any suggestions where to find one, how to fix this one, a proven way to change it and not use the + connector.. Anyone?
NSR-lizard
Thu Jan 20, 2011 4:40 pm » Post: #3 » Download Post
Maybe posting it in Classifieds may have helped? Rolling Eyes
Vampire?
shmokica
1990 Honda NSR250 MC21
Thu Jan 20, 2011 9:28 pm » Post: #4 » Download Post
Plastic repair kit will do the trick. I use Q-bond -> http://www.qbond.net/pg_1/pg_1.htm
You will need to make sure the epoxy that you already put on is not blocking the air passageways. Depending on how it's broken, you may need another hand to hold it together. Sprinkle on the plastic powder around the break, a few drops of the solvent, wait a bit, then turn it over and do the other side.
I have ocd, so I'd probably hold it together and use a small die grinder attachment on the dremel to put a u shape channel around the break, this will allow you to get an almost invisible repair, and it will give you a larger bonded surface.
If it's a standard black X piece, it's marginal whether the cost of the repair kit is worth it, although you will have plenty left to repair fairing cracks etc. If it's a HRC piece ie Red, then definately worth repairing.
