hi
i want to change the oil the previous owner was using on my bike,i was wondering if i need to purge the lines or if just emptying out the tank and refilling it is good enough?also does the pump need to be primed in any way after removing the oil lines to the carb?
There's an air bleed nut on the top of the oil pump think its shown on the workshop setion on setting up the oil pump . _________________ it wouldn't be fun if it was easy!
