Honda RS250 1991 clutch Centre
shipleymanx
Fri Feb 11, 2011 8:16 am » Post: #1 » Download Post
Hi, does any body know if there is an alternative fit for machine. The clutch centres are non existant so wondering if any body knew what else could be modified to fit. thanks
Fri Feb 11, 2011 9:28 am » Post: #2 » Download Post
How much are you prepared to modify?
I've fitted an RS inner and outer to an NSR by basically cutting the middle of one out and the outside of the other and then welding them together.
You can get anything to fit if you have a lathe, a TIG welder and time on your hands.
{.bLanK}GoD
Sun Feb 13, 2011 7:20 am » Post: #3 » Download Post
The inner clutch basket?
Your not looking hard enough.
I would tell you where to buy one, but I'm not allowed.
