mc28 suspension
kyocrane
mc28 suspension
Tue Feb 01, 2011 3:04 pm » Post: #1 » Download Post
I feel like rebuliding my MC28 stock suspension, can anyone give me some advice please?
Thank you.
mixalisen
Tue Feb 01, 2011 3:58 pm » Post: #2 » Download Post
Hi,
Find a good shop that knows about suspensions and talk with them about anything you want to know... Talk with them about the springs that your MC28 is eqiupted now and ask them if they are ok for your weight...
Regards
Michael
Nash823
Sun Feb 06, 2011 12:31 pm » Post: #3 » Download Post
Its a pain in the ass here as there are not many good suspension shops here, even the good ones have bad rep with MC28's cuz they dont know how to rebuilb them, i dont know why too..
nxrsr20
Sun Feb 06, 2011 7:25 pm » Post: #4 » Download Post
buy an aftermarket unit or find one that is roughly equivalent.
eg the CBR600f4i shock is an almost good swap, got a good spring rate, about 10mm longer, just need to sort out the reservoir hose issue and it'll be in my bike Wink
Fri Feb 11, 2011 11:25 am » Post: #5 » Download Post
If you're talking forks, then any decent bike shop should be able to rebuild them.
Rear shock is a little more specialist, but can be done at home if you have some simple tools and a bottle of nitrogen in the shed.
kyocrane
Fri Feb 11, 2011 4:18 pm » Post: #6 » Download Post
Thank for all the reply, i really feel like rebulidung it but don't have the info needed.
nxrsr20
Fri Feb 11, 2011 9:22 pm » Post: #7 » Download Post
Matt: What pressure is needed to gas a shock up to? Wegot a workshop at work where I can do it, but I don't know what pressure.
kyocrane: rebuilding front forks is easy, I'm in the process of doing that now, I just want to source some bushings. I can take photos of it if you want.
mighty max
Sat Feb 12, 2011 12:15 am » Post: #8 » Download Post
Post some pics pls...
Sat Feb 12, 2011 9:44 am » Post: #9 » Download Post
Rear shock 10 bar. That's about 145psi. Please be very aware that a gas under pressure can kill you!
Having said that, the first time I rebuilt a so-called non-rebuilable rear shock I was all togged up with leather apron, face shield etc etc and got a very disappointing pop when I drilled through the end cap to release the gas. High pressure but relatively small volume.
When rebuilding you must make absolutely sure that there's no air bubbles. When I'm pumping the damper rod through the fluid I give it a few sharp cracks with a brass mallet to 'shock' the air bubbles out of the damper valve.
You will spill oil all over the floor. Not just once. Then you'll pull the damper rod up too high, suck air in and have to start again. Be prepared to overflow the oil just to make sure there's no air pockets hiding.
The nitrogen is contained in a rubber bladder in the reservoir tank. I like to fit this all deflated so that there's essentially too much oil in the shock. Then I set one of the banjo bolts on the hole at a high point and let any remaining air bubbles settle at this high point. Tapping the shock body helps release any sneaky bubbles that are hiding.
Oh yeah, forgot to say that you'll need to fit a valve to the reservoir tank cap so that you can refill the gas. There's a couple of types generally used. Either a schrader valve, which is the same as the one you see on your tyres, or a rubber bung type. The latter requires a hypodermic needle to refill, whereas the schrader can use a normal airline fitting that you can buy anywhere.
nxrsr20
Sat Mar 12, 2011 11:32 pm » Post: #10 » Download Post
Alright, I totally forgot to get a photographer whilst I was doing my fork rebuild, but this is a great guide to use, the forks are almost identical, just remember to measure the correct oil height for the forks you are working on, and to write down your settings before you start undoing things!
http://www.bluepoof.com/motorcycles/howto/svs_fork_oil/
