exhaust bridge
eggy74
exhaust bridge
Wed Apr 13, 2011 10:07 pm » Post: #1 » Download Post
hi all,
just joined the forum today so hi to you all, i have afew questions for you all, as my ive just had to take my mc15 r5k apart again, i had my barrells plated by langcorts about 500 miles ago and just had a minor nip up, ive taken the barrells off to inspect them and both have marks on the pistons and rings where they have been passing over the exhaust port bridge, im guessing they were never releived after they were plated, my question is can i releive them myself with, say 400 grit paper, if so how deep should i go ? 0.05 mm perhaps ??? and lastly will i wear through the nikosil doing this and does it matter
thanks for any light you guys can shed on this for me
steve
eggy74
Thu Apr 14, 2011 6:31 am » Post: #2 » Download Post
mc18 sorry
anonymous.shyster
Fri Apr 15, 2011 8:00 am » Post: #3 » Download Post
Hello!
Not sure what you mean by releived, or what you're trying to do.
How deep are the marks? You'll get better information from here if you can figure out how to post pictures.
Check for cracks on the exhaust bridge. They're bad and will be a major cause of the wear of which you speak.
mc 15? What is that? I haven't heard of one and google images would have me believe it is some sort of ultralight, a subwoffer or some really ugly girl pulling faces.
anonymous.shyster
Fri Apr 15, 2011 8:01 am » Post: #4 » Download Post
Oh, mc18, my bad!
2T Institute
Sun Apr 17, 2011 3:51 am » Post: #5 » Download Post
If you have hone marks on the exhaust bridge send it back to the platers as there will be no clearence for the brdge to expand out when hot.
{.bLanK}GoD
Mon Apr 18, 2011 4:51 am » Post: #6 » Download Post
I would assume relieving the exhaust bridge needs to be done before plating. Either way, I wouldn't screw with it if I were you.
geckoracing1
1996 Honda NSR250 MC28
Mon Apr 18, 2011 6:10 am » Post: #7 » Download Post
Hi Steve
Sorry to hear your bike nipped up.
Yes, ideally the exhaust port bridge should be relieved after being replated and before use - to give the thin bridge room to expand. (As the bridge is thin it heats up faster than the rest of the cylinder and expands faster, & can sometimes rub the piston). I'd be surprised if the plater hadn't done this though, they usually know their stuff - it's their business to know. If the seizure is very light, you can often get away with super fine wet and dry if you are patient. If it has broken through the chrome, the best thing is to get them replated. On the piston, it's good practice (if you are racing) to relieve the piston ring groove at the point where it runs over the bridge. This you do with a small triangulated fine file, again this allows the ring to run freely in the groove should it get hot or the groove start to peen over.
Dan
www.geckomotorcycles.co.uk
Neal
Tue Apr 19, 2011 7:26 pm » Post: #8 » Download Post
And countersink the drilled holes on the piston .it helps the oil collect there and lube the exhaust bridge .
