Hi All. I am having problems with pistons and rings on an NSR 250 (MC21) I am bebuilding.  More specifically, pistons (pn 13102-KV3-830)and rings (pn 13010-KV3-305) I purchased  don't seem correct for the rebuild.  The pistons seem to require a flat/rail ring in the bottom groove and a serpentine ring in the top groove.  The rings I received (as numbered above) appear to both be flat/rail style rings and do not fit into the top groove.  Have you run into this before and if so, where can I get the correct rings?
Mark
What's the latest?
