(wet) clutch basket play
cangus
Fri May 20, 2011 12:45 am » Post: #1 » Download Post
i am in process of replacing clutch plates and noticed that the clutch basket (outer basket) moves about 1/8" whilst the drive gear does not move at all. is there supposed to be any freeplay between the gear and basket?
MC21R9N track
MC18R2J track
CBR954
CR250
Fri May 20, 2011 11:05 am » Post: #2 » Download Post
Do you mean that with the plates fitted the basket moves a small amount before the shaft moves?
cangus
Fri May 20, 2011 6:28 pm » Post: #3 » Download Post
no plates are installed. the outer basket is installed on the transmission shaft. the outer basket turns about 1/8" while the large gear on the back side of the basket is held fixed.
or you can remove the clutch basket and whilst in your hand turn the gear on the back side back and forth, again about 1/8" at the outer radius.
there are some type of rivets that attach the steel gear to the aluminum basket. they do not appear to be removable. it's my guess that this should be a rigid assembly and that wear/use/abuse has loosened this connection. the basket has a good bit of wear. looking to find out if it needs replacement or if this slack is normal. thanks.
MC21R9N track
MC18R2J track
CBR954
CR250
NSR-LOVER
Sun May 22, 2011 12:58 am » Post: #4 » Download Post
had the same problem, didnt notice something wrong i just found out it was moving( the basket against the gear) so i found an other basket and had no free play at all so i installed it...
maybe you can ride the bike and all good and nice but normally there shouldnt be free play there...
elmo
Mon May 23, 2011 2:27 am » Post: #5 » Download Post
no there should be no play ive noticed some have bolts and some have riverts i dont no why "anyone"
i may have a spare good basket if your interested
"Batmans a scientist"
cangus
Mon May 23, 2011 6:12 pm » Post: #6 » Download Post
that's what i was afraid of. thanks for the info.
got moriwaki man working on a clutch basket for me but thanks for the offer. will keep if in mind if something changes.
MC21R9N track
MC18R2J track
CBR954
CR250
