So for my track bike build I plan to remove the ignition switch and run the bike from the kill switch only.
In addition I will be running the bike without the GPS, and have already done the O/Bu to Bl/W splice.
Are there any other bits that are going to catch me out I need to close off in the loom? Neutral switch?
I'm not running the oil pump, what about those wires?
You're better off rewiring it so that the kill switch acts as the key switch. The kill switch still leaves power to run lights (dash lights maybe in your case), and other idle processes in the PGM so you'll eventually flatten your battery.
Don't forget your side stand switch.
When do you reckon your bike will be ready? It'll be good to see another stroker on the track.
So I rewired the Red and Red/Black wires of the ignition into the kill switch, and simply joined off the two wires (Black and Black white) that used to go into the kill switch.
Should do the job.
Bike must be done by the end of Feb to run it in and tune it, so I am ready for March racing.
From the looks of the Preston events, you'd have to enter against the GP bikes. Good luck and let us know when you're racing, I'll try to get up and say hi.
Are you cutting your loom down as well? What "weight loss" program are you following?
PLugged in battery and nothing. Read up on the forums, crank the RC servo to 'high', switch the bike on and nothing.
Attach a spark plug to the coils and turn the engine over and 'nothing'. Lots and lots of nothing.
In sheer desperation after scratching my head, reading and rereading the wiring diagram, testing and retesting wires I tried the spare completely unmolested loom.
Wired up the side stand switch
Wired up the ignition
Attached the kill switch and everything else above and
More facking nothing. Swapped out all the spare components (solenoids, RC servo) and still nothing.
So I am either missing something having converted the bike to total loss, or my PGM3 is fscked. Someone please tell me I am missing something.
I've lost all motiviation. Fscking arsehole thing.
Are you sure you haven't made something wrong with the kill switch?
If you have nothing working -not even the dummy lights at least?-,
then I'm pretty sure it's something simple that you forgot to connect and it's just sitting there laughing at you. _________________ 2t-racelab.com
