RS 250 1991 ignition coil and clutch
shipleymanx
Sun Jul 17, 2011 9:19 pm » Post: #1 » Download Post
Hi there, does any body know if there is an altrnative to the 1991 ignition coil for a RS250. Also has any body had problems with the clutch and new friction plates. I has some new plates made, when i fit them the last steel plate was right on the end on the centre hub,so when the clutch is pressed there is a danger that this plate could become dislodged. The only way i can get it right is to leave out one metal plate. Is this a done thing. cheers
