fly wheel
This topic is locked: you cannot edit posts or make replies.   printer-friendly view
kukkos
fly wheel
Thu Sep 22, 2011 9:07 am » Post: #1 » Download Post
Hi guys, I,m interested to A.C.HRC flywheel 31100-nkd-970 (very expansive)
Question: this flywheel work on my MC28 wire loom modified to(hrc card 030)
and the lights, and battery charge, work with this item?'
Guys can give me information.. Laughing
P.s (help me Matt and fontyyy Crying or Very sad )
Alessandro Cucco
via Brigate Partigiane 43c
54033 Carrara (MS) Italy
Thu Sep 22, 2011 9:32 am » Post: #2 » Download Post
I think you have already asked this question in the HRC section have you not?
kukkos
Thu Sep 22, 2011 1:56 pm » Post: #3 » Download Post
yes bat I don't access to hrc forum I'm carbon member!! Crying or Very sad
Alessandro Cucco
diviCe
Thu Sep 22, 2011 2:52 pm » Post: #4 » Download Post
Yes... it works - simply plug 'n' play!
cookiesol
Fri Sep 23, 2011 4:23 am » Post: #5 » Download Post
i tot the 030 already has ignition advance.
so is it advisable to still use the hrc or mc21 flywheel or even the 2 degree woodruff key?
Fri Sep 23, 2011 5:31 am » Post: #6 » Download Post
HRC support is only in the Members Area.
kukkos
Flywheel
Fri Sep 23, 2011 8:59 am » Post: #7 » Download Post
I'm Sorry Andy ! Embarassed
I ask only this information to be sure of the operation (recharge battery and lights ok )
I' don't purchase this part if not work !
I'm carbon member now !
You can me send P.M for this info !I think you can understand me Crying or Very sad
Alessandro Cucco
Fri Sep 23, 2011 12:59 pm » Post: #8 » Download Post
The message was in response to cookiesol asking about a performance related question regarding the HRC flywheel.
As divice says, the flywheel is just a plug'n'play item... it uses the same connector as the OEM harness.
kukkos
Flywheel
Fri Sep 30, 2011 1:55 pm » Post: #9 » Download Post
Ok it's a plug and play, bat recharge is not enough for Mc 28 battery , HRC has created it for race
There is possibility to use on MC 28 standard wire and battery ?
See my P.M
Thanks
Alessandro Cucco
Fri Sep 30, 2011 4:54 pm » Post: #10 » Download Post
Simple answer is no-one here really knows! As far as I'm aware, no-one of the forum has ever actually used the HRC generator as it's so damn expensive, and the gain will be marginal relative to the cost. You could save more weight by going to the toilet before going out for a ride! What you may gain is a little crisper throttle response.
Given the size of the stator, I would assume that it only really generates enough power to run the basic electrics. I don't reckon it will keep up with the discharge rate of the battery if you use lights, indicators, horn, brake lights etc.
Making a race AC generator that's capable of producing enough currant to run road electrics was probably the last thing HRC were thinking about when trying to screw as much as they could out of the MC28 for the SP class.
Just my opinion and best guess, given the information available.
kukkos
Flywheel
Fri Sep 30, 2011 5:37 pm » Post: #11 » Download Post
Thank you Very Much Andy Wink for your availability' and patience Embarassed
Alessandro Cucco
mixalisen
Sat Oct 01, 2011 9:34 am » Post: #12 » Download Post
Hi Kukkos,
i have use the MC28 HRC Flywheel and stator in the past to my MC28 (i have sold it now)... As Andy correct said this part was made only to produce enough current for the PGM + Coils + RC Servo Motor and stuff like that... As for the gain that you will have will be noticible only i think on the dyno... At least i didn't feel any difference vs stock set up when i rode my bike...
But most people here don't care if they have a major gain from a part but they care most if it is a genuine HRC part (i am one of them to be honest Embarassed )... This is a big true that most of the guys here have to admit...!!!
Michael
Sat Oct 01, 2011 12:21 pm » Post: #13 » Download Post
That's because we KNOW it's faster, just because it says HRC on it. Cool
mixalisen
Sat Oct 01, 2011 12:28 pm » Post: #14 » Download Post
How can i argue with that now Dave...??? Embarassed
Sat Oct 01, 2011 4:32 pm » Post: #15 » Download Post
Dave Ett wrote:That's because we KNOW it's faster, just because it says HRC on it. Cool
It's also going to be in this case something like a grand or so for a gain I'll bet is under 1 bhp.
