I have these calipers which I want to fit.
No problem there.
The problem is correct discs for these calipers are 290mm diameter not 296mm diameter like the standard NX5 discs.
I have seen a couple of bikes fitted with what I think are the correct 290mm Brembo discs I'm after, an NF5 RS as below and also an MC21 with and NX5 front end fitted to it.
I pretty sure NF5 RS's used 296mm diameter discs?
Am I getting my knickers in a twist over nothing??? What's 3mm between friends...
Yes, I do know I could just use the standard Honda discs or any other 296mm diameter discs with the correct offset but wheres the fun in that?!
Any help would be appreciated.
