What cranking pressure??
FASTFILL
Wed Jan 18, 2012 6:01 pm » Post: #1 » Download Post
HI
Thought I would delve inside my mc 18 2rk to check its in good nick and maybe do a bit of a clean up!
The cold cranking pressures are 95 psi and 98 which seems good to me! but my most recent 2 stroke experience was tuned lc s a long time ago when anything up near 100 psi was very very good!
Could you more experienced nsr people let me know?
Cheers Phil
Dmitry
Wed Jan 18, 2012 9:40 pm » Post: #2 » Download Post
I assume you talking about compression?
on my running MC18 PGM2 I have about 130 on both cylinders. I also have a blown up motor that was 140 and 70 psi
70psi barrel was toast
FASTFILL
pressure
Thu Jan 19, 2012 9:32 am » Post: #3 » Download Post
Thanks for info
FASTFILL
toneless
Thu Jan 19, 2012 10:10 am » Post: #4 » Download Post
Assuming that nsr runs a "corrected" compression ratio of 7.4:1,
I reckon readings should be 107 psi and above?
2t-racelab.com
FASTFILL
Cranking Pressure
Thu Jan 19, 2012 4:24 pm » Post: #5 » Download Post
hI
Matt at Tyga says 120 - 125 on fresh motor (standard)is what to aim for !
FASTFILL
Mon Jan 23, 2012 11:52 am » Post: #6 » Download Post
The service manual gives 10 kg/cm^2, which is 142psi. What I can't tell is if that's RC valve open or closed.
Mon Jan 23, 2012 9:21 pm » Post: #7 » Download Post
My engine has made 120-130 the couple of times I've tested it.
