Hi there.
Does anyone out there have new crankshaft seals and clutch plates available?
The small one is same as NX5 and NXA so that is not a problem, but the big one is slightly different to the NSR one.
It is the same as the early MC16RG and MC18 R2J and R4J, they are 10mm wide as opposed to the later NSRs which are 8mm wide.
PN: 91203-KV3-003 and 91201-KM4-003
Not sure of cross application of clutch plates but part numbers are not the same between NF5, NX5, NXA and NSRs.
Interested also in new '92 crankshaft.
Steve
