Back On Track!
noidea
Back On Track!
Thu Feb 16, 2012 11:51 pm » Post: #1 » Download Post
Hi All,
I've got an MC21 that I've owned for about 5 years, but never ridden. I bought it from a mate who only used it for Ride days untill he dropped his roadbike and the fear set in and he sold everything!
I got the top end rebuilt about 4 years ago, and had all the servicing done then aswell. I've recenty put new brake pads front and rear and yesterday bought some new tyres for it, I wanna get back into the ride days ASAP. (the off-road bike has eaten all my free time over the last 3 or 4 years)
What should I do to the bike before I get to the Track?
I'm thinking brake fluids & gearbox oil??
Will the 2t oil in the reservoir still be ok? Should I even be using the 2t oil reservoir, or should I premix my fuel?
Thanks for any input!
Al.
nxrsr20
Fri Feb 17, 2012 12:59 am » Post: #2 » Download Post
welcome back, I'm doing a track day on March 3@ Broadford, there will be a few strokers up there too Smile
The basic road worthy checks (minus lights and indicators and mirrors) are what's checked. Definitely do a fluid flush if it's been 4 years, all my 2T bikes run the oil pump so don't change that.
If you need a hand with anything, drop me a line.
noidea
Fri Feb 17, 2012 2:58 am » Post: #3 » Download Post
Cheers mate, I might even see you there if I can get myself organised!
noidea
Mon Mar 05, 2012 3:18 am » Post: #4 » Download Post
OK I have two questions that I'm sure you will find easy to answer!
Is there an oil filter and where is it?
and,
How do I remove the power valve to check it is ok?
Told you they where easy questions....
Neal
Mon Mar 05, 2012 5:03 am » Post: #5 » Download Post
You Need to buy the powervalve tool from Tyga , it makes the job simple . Loosen the pulley and see how easy it is to rotate the shaft . If it is stiff , service it . If it is free then you are safe
