  • NSR250 Forums Index ‹ NSR300 Discussion
300 piston and barrel
Manny Fagnet
Tue Mar 13, 2012 9:56 am » Post: #1 » Download Post
HI, just got into the bike since Sept problems (busy or what) and Andy was right it had nipped up.
Not repairable as both have a bit missing and a badly scored barrel.
I now need a piston and barrel for a TYGA 300 conversion. Has anyone got one on a shelf? Please?
if it had a tail - it would wag
Tue Mar 13, 2012 11:51 am » Post: #2 » Download Post
Do you just need 1 barrel and piston or 2?
I think I've still got some stock 300 barrels somewhere but no pistons. If I recall though the barrels will need re-plating but aren't damaged.
What pistons are you using the ART or Wiseco?
Manny Fagnet
Wed Mar 14, 2012 11:08 am » Post: #3 » Download Post
Thanks Stephen. I need just the 1.
I have the chance for a Wiseco piston to go with one of your barrels, which could sort my summer.
However I honestly have no Idea what is in there. I'll check my paperwork from TYGA and see if I have the info or is there a easy way to identify the make. I only have the head off at the minute.
If the Wiseco piston goes with what I have i'll buy one off you please. What does the coating process involve though?
Thanks Mal
Wed Mar 14, 2012 5:10 pm » Post: #4 » Download Post
The wiseco pistons come from Tyga and fit the 300 barrel as intended . If you have a barrel replated , you send you new piston with the barrel and you can specify a clearance
If you are fussy and racing . Or you use the clearance they advise you to use
Manny Fagnet
Thu Mar 15, 2012 9:03 pm » Post: #5 » Download Post
Stephen I am grateful for your help. PM me and I'll sort the purchase out, if that's ok.
Manny Fagnet
Fri Mar 30, 2012 12:10 pm » Post: #6 » Download Post
StephenRC45 wrote:Do you just need 1 barrel and piston or 2?
Hi Stephen, If you still have a barrel I have a Wiseco piston on the way and would love to do a deal.
If not has anyone else got a barrel from a 300 kit on a shelf, please.
No ride this summer otherwise.
Thanks.
NSR300 Discussion
