Hi all
I'm still after a few bits n bobs for my 18,
I'm after the alloy gear change bit that goes onto gear shaft with the ball joint,
Also the wire bit that goes onto the oil bottle,holds the oil filler bung in place (2 stroke oil filler cap wire springy thing! )
Then I have a completely fully rebuilt bike ,
Oh still after an 18 rear Magtek sprocket carrier if any one has one,
Many thanks _________________ NSR250 MC18
Last time I checked you could still buy the gear change part new. The alloy tends to strech fairly quickly though _________________ Why do things simply when you can complicate them
