I have a few nsr's and an ns400 and want to clarify the interchangeability of nsr crank's. I know there are differences in mc18 MK2, mc21 and mc28 but are they interchangeable? Different crankwebs, flywheel etc? What would be required to put a 28 crank in an r5k if it's possible? I have all these and an r2j which I understand is quite different, and just want to know the finer details of each. Thanx for any input/ links.
R2/4J MC18 - 96mm crank webs, center seal next to middle bearing.
R5K MC18 - 96mm crank webs, integrated center seal into middle bearing, same as 21/28.
MC21/28 - 100mm crank webs, integrated center seal into middle bearing.
R2/4J cranks can only be used in R2/4J casings.
R5K cranks can be used in R5K casings and MC21/28 but not advisable.
MC21/28 cranks can be used in MC21/28 casings only.
As for your question what you would need to put the 28 crank(100mm) into your R5K casings, you need MC21/28 casings as the crank webs is too wide for the R5K casings(96mm). You can still use the same flywheel and pickups.
You can turn MC21 cranks down to fit R5/6K crank cases. See pictures on NSR-World's face book page of ours. _________________ If I have to take the carbs off once more...
