Rust inside tank
Bully
1994 Honda NSR250MC28SE
Rust inside tank
Sun Sep 16, 2012 7:19 pm » Post: #1 » Download Post
I have a spare tank which I am planning to fit when my cheapo fairings come down. Am mothballing the original bodywork as its too precious if it gets damaged.
The tank has some rust in it, I have got rid of some of it but not all of it.
Someone recommended sealing it, petseal, but I have read some horror stories about it.
Any recommendations?
or has anyone got a 28 tank with no rust inside lying around to sell me cheaply?
Lemon owner and lover
Roman250
Mon Sep 17, 2012 5:32 am » Post: #2 » Download Post
there are many products that people swear by. there are also DIY techniques to get the rust out by putting in small metallic objects (ball bearings for example) and spinning the tank. i just de-rusted mine with some vinegar and baking soda. just google away and there are dozens of solutions.
Lane
Mon Sep 17, 2012 6:13 am » Post: #3 » Download Post
I prefer to use a length of small chain as it's much easier to remove.
toneless
Mon Sep 17, 2012 10:52 pm » Post: #4 » Download Post
If the fuel tank is not that bad then electrolytic rust removal will be a good choice.
If it's in very bad state, then use an epoxy sealer kit.
2t-racelab.com
Dmitry
Tue Sep 18, 2012 3:29 am » Post: #5 » Download Post
Step 1: used combination of nuts and bolts inside the tank, with tank packed with blankets inside clothes dryer (Heat OFF) set on tumble for 30 minutes at a time, repositioning it every 1/2 hour. We have an old dryer at the shop just for that
Step 2: is a product called Metal Rescue, some type of acid but it works well and it was cheap enough
before
after
Step 3: rinsed with water and then rubbing alcohol to get rid of moisture and that's what it looks like
For good measure coated it with Caswell epoxy
Bully
Tue Sep 18, 2012 7:14 am » Post: #6 » Download Post
Cheers guys will try to get some pics up this weekend of the inside to show you what the rust is like.
