compatible cylinder rear cylinder head for mc18 r5k?
andyburton1977
Sat Sep 15, 2012 6:03 pm » Post: #1 » Download Post
hi everybody,
i have bought my first NSR250, its the MC18 R5K 1989 and i have my first question for you all.
can anybody tell me if any other model of NSR or Honda 2 stroke engine uses cylinder heads that are compatible with the MC18 R5K rear cylinder please?
cheers!
andy
Sat Sep 15, 2012 7:06 pm » Post: #2 » Download Post
1988 R2/4J heads will fit, and you may get away with an 1987 MC16 head, although it will take a little creative plumbing as the outlet differs to the MC18.
Using an MC16 head may also effect the compression ratio.
Only 87-89 heads share the same patterns. No other models share heads with NSR250s.
2Smoke
1987 Honda NSR250 MC16
Sat Sep 15, 2012 8:23 pm » Post: #3 » Download Post
Mate, if I'd have known I'd have told you to pop down to Aintree, I had a head in my spares kit today!
andyburton1977
mc16 head compression ratio
Sat Sep 15, 2012 8:29 pm » Post: #4 » Download Post
hey andy,
thanks for the info.
i agree that the mc16 head probably will alter the compression ratio seeing as the mc16 engine runs a lower compression figure and i expect the squish area/angle is different also?
cheers pal
andyburton1977
mc18 rear cylinder head
Sat Sep 15, 2012 8:34 pm » Post: #5 » Download Post
hey 2smoke
where are you based?
do you have a suitable cylinder head i can buy please?
cheers pal
andy
