Rear Axle Parts Help!
kneewall49
Wed Dec 12, 2012 10:08 am » Post: #1 » Download Post
Can some one point out to me which of the three parts I have pictured below, are the numbers #5. #8 and #17 on the parts list for the rear wheel?
Forgot to take a pic on dismantling. Embarassed Sad
Neil
Alzazorq
Wed Dec 12, 2012 1:50 pm » Post: #2 » Download Post
Hey Neil,
On photo :
Left - No 4/19, photo very small,outside on sprocket carrier.
Middle - No5 , disc side.
Right - No8, between rim and sprocket carrier.
Chow,
Mario
kneewall49
Wed Dec 12, 2012 8:01 pm » Post: #3 » Download Post
Thanks Mario!
Could I ask what items are #19 s are, are these simply the bearing dust seals or they some other type of seal?
Neil
kneewall49
Wed Dec 12, 2012 10:01 pm » Post: #4 » Download Post
I mean are they the seals that fit inside the bearing edge covering the balls, or are these an additional seal?
Alzazorq
Thu Dec 13, 2012 9:45 am » Post: #5 » Download Post
kneewall49 wrote:I mean are they the seals that fit inside the bearing edge covering the balls, or are these an additional seal?
They are seals, on end of the spacer fits into the bearing, the cap between the spacer and sprocket/wheel is made up with a dust seal.
The bearings them self are the sealed type.
Chow
Mario
kneewall49
Thu Dec 13, 2012 9:58 am » Post: #6 » Download Post
Thank you. They appear to be missing from my two? Fronts have seals, the backs haven't.
Alzazorq
Thu Dec 13, 2012 1:47 pm » Post: #7 » Download Post
kneewall49 wrote:Thank you. They appear to be missing from my two? Fronts have seals, the backs haven't.
That's correct, like the front the rear also need dust seals.
