Tyga special exhaust collar - How to seal?
das134
Sat Dec 01, 2012 7:50 am » Post: #1 » Download Post
Hi guys, when installing the Tyga 'special' exahaust manifold collar, is it necessary to use Honda OEM gaskets?
What have people done?
Having issues getting a good seal...
Satchriossi
Sat Dec 01, 2012 8:05 am » Post: #2 » Download Post
I smear Threebond 1207B on the mating surfaces - seems to keep the black goo in check for a fair while.
Sat Dec 01, 2012 8:11 pm » Post: #3 » Download Post
Between the TYGA stub and the cylinder you will need to use the Honda OE gasket. Between the stub and exhaust use a Threebond.
anonymous.shyster
Sun Dec 02, 2012 3:36 am » Post: #4 » Download Post
I found a fix quite some time ago to the leaking exhaust issues. Here is a post describing what I did:
http://nsr250.net/forums/viewtopic.php?t=10650&highlight=leaky
Main points:
Don't use the orange RTV sealant - use the high quality grey stuff, it's rated to higher temperatures
Use the KTM vitron o-rings
PTFE tape around where the flanges slide in may also help
Mine haven't leaked since following this method. Hope this helps.
das134
Thu Dec 06, 2012 9:02 am » Post: #5 » Download Post
Interesting ideas...
Mine is a race bike so the exhaust is coming off fairly regularly. I guess I'll stick with the Honda gaskets for now then get a bit more extreme if needed.
Are those gaskets NSR specific or are they readily accessible?
