mc21 nipped up :(
marcus127
mc21 nipped up :(
Sun Jan 06, 2013 4:22 pm » Post: #1 » Download Post
hi ive had my 21 for harf a year now was inported and had the engine rebuilt and a few other bits done really like it
i de-restricted it and put some tyga cans on it run it in, giving it some for a bit all seemed good, took her out in the sun yesterday thought i would take it and do a plug chop so flat in 6gear up to 115 ish coming of the gas and i could feel it was going to nip up clutch in engine cut out got my dad to pick me up the top pot seized barrel looks ok piston second hand now looks like it got to hot oil feed ok
so here it is what pistons are better honda or wiseco ect, its a road bike with a owner that likes to ride fast Smile and what main jets would you say it needs i think i would like to go bigger and lose a bit of power
and i dont no what pistons are in it no honda marking or any thing i could see
thanks guys and girls
Sun Jan 06, 2013 4:26 pm » Post: #2 » Download Post
The Honda pistons are superb. I wouldn't use anything else in a road NSR. The only other piston I would use is the ART HRC piston, but that wont work with an otherwise stock motor.
No jetting talk on the open forum. There's a jetting page in the members section however.
marcus127
Mon Jan 07, 2013 4:43 pm » Post: #3 » Download Post
ok thanks for that ordered standard honda pistons
i think i found how it happened the bass gasket had gone so would that have been sucking in air ? because the other piston and barrel are fine and thinking about it the seize piston and barrel had a gray like paist on it could of been coolant
nobby62
Fri Jan 11, 2013 7:17 pm » Post: #4 » Download Post
grey paste more likely to be vapourised aluminium from the piston...... have a good look
Fri Jan 11, 2013 11:44 pm » Post: #5 » Download Post
You could have been looking at the greyish creamy gunge you get when water and oil get mixed together.
marcus127
Sat Jan 12, 2013 1:50 pm » Post: #6 » Download Post
Thanks for the replys I think nobby62 is right because the coolant was fine so do you think the bass gasket would of done that then sucking in air and nipped up because the other cylinder is fine
nobby62
Mon Jan 14, 2013 9:04 pm » Post: #7 » Download Post
Its impossible to diagnose accurately without seeing the damage... but if air was getting in then you would have been running lean and thus having high temperature and detonation...
