After a bit of advice or some ideas on peoples experiences with anodizing or powder coating an MC21 swingarm.
I believe the anodizing will be more durable but i've heard that the rough sections can come out a little dark and it can fade or stain easily with solvents? Although i imagine this may be the result of poor workmanship rather than a flaw of the process itself?
Powder coating is my other option in a metallic satin silver finish.
Hi there Lane ,take a look at my swingarm on my white 21 trackbike in current builds,it had a nasty dent in the side were a footrest made contact,so i repaired the dent and powdered it in satin silver,i agree its not the same as the brushed alloy effect,but i seen alot worse,let me know your thoughts,jonmac, _________________ John
Thanks Jon, that's all the inspiration i need, agreed the brushed, factory finish looks the the best, i have two swingarms here, one has an ugly gouge similar to yours that has met with a rearset at some stage that makes anodizing a hassle, and the other has a missing pick up spool and a large graze.
Think i'll duck down to the coaters on Monday and get him to add the swinger to the parts being done at the moment.
Problem with anodizing the part that has already been anodized is that you have to strip old finish first and for that they will dip it in Acid which will leave the surface mat, then you will have to polish it and apply the brushed finish before having it anodized, lot's of work...
I have had some success cleaning up the frame and swingarm using fine grit sanding pad (2000 or more) and water
In the past i have used oven cleaner to strip old anodizing and prepare the surface myself but in this instance i'ce decided to powdercoat the swinger.
