MC28SP Fork Damper Rebuild
ericandchi
Wed Sep 11, 2013 11:08 pm » Post: #1 » Download Post
Hi folks,
I am rebuilding by MC28SP forks. I needed a new seal on one side so decided to also install a Race Tech Gold Valve as well. I have not been able to figure out how to take apart the damper - remove the compression valve holder. I suspect there is a simple trick, but it's not clear in the parts manual or shop manual. I've included some pics below in hopes that someone can help.
MC28 SP
Thu Sep 12, 2013 12:10 am » Post: #2 » Download Post
I thought it was just held in with a circlip?
If memory serves me correct, you just compress it, and you will see a clip (like a bit gudgeon/wrist pin circlip) in a groove in the top of the stanchion.
ericandchi
Thu Sep 12, 2013 2:59 am » Post: #3 » Download Post
.Just as you said. It is now apart. I will report back in a month or so on how well the damping kit works.
