Blanking extra oil feed hole MC28
das134
Sat May 24, 2014 11:21 am » Post: #1 » Download Post
Hi guys, how have you gone about blanking the extra oil feed hole on the later mc21 and mc28 engines?
I didn't even know it was there!
Mon May 26, 2014 9:09 am » Post: #2 » Download Post
With a 4.5x8 o-ring, there's an HRC part number for it (90807-NKD-940).
das134
Mon May 26, 2014 10:44 am » Post: #3 » Download Post
fontyyy wrote:With a 4.5x8 o-ring, there's an HRC part number for it (90807-NKD-940).
Don't have the engine in front of me today so can't check, but how does this work? It just looks like a small hole, wouldn't you need more than an o-ring?
Mon May 26, 2014 3:57 pm » Post: #4 » Download Post
Ah, my mistake - bad memory.
The HRC part is a plug, or you can use an o-ring and a big blanking plate.
It's been a while since I put a 2t race motor together - sorry Embarassed
kan3
Mon May 26, 2014 9:29 pm » Post: #5 » Download Post
You leak test and find it? =]
I use an o-ring and plate along with a plug for the oil pump shaft.
das134
Tue May 27, 2014 12:25 am » Post: #6 » Download Post
Nah no leak test (yet). Just wondered what was going on when I took off the pump as my older engine didn't have it. So an o-ring and a plate... Will see if I can make something up.
Neal
Tue May 27, 2014 2:40 am » Post: #7 » Download Post
Look on tyga performance for the blanking plug .
NSR300
das134
Tue May 27, 2014 10:28 am » Post: #8 » Download Post
Neal wrote:Look on tyga performance for the blanking plug .
Is there one also for that small hole next to the oil pump shaft hole?
