Are there any special pliers for these clips?
gepe
Fri Oct 25, 2013 7:50 pm » Post: #1 » Download Post
I hate these:
Is there a special tool to open them and move them in the open state?
Thanks!
gepe.
80XAR
Sat Oct 26, 2013 1:42 pm » Post: #2 » Download Post
Hmmm. A set on pliers is usually enough when they are closed like in your picture. I've also used a big flat blade screwdriver to open them up further. Put the flat blade between the 2 loops and twist it open. You should end up with loops sitting on each side of the flat blade. It's a little tricky to get them onto a hose like that, but once on a hose, it's easy to slide them up the hose using that method.
They only have a narrow clamp range, so make sure you are not using a clamp that is too small for the hose.
cgallant
2001 Honda RS250
Sat Oct 26, 2013 2:30 pm » Post: #3 » Download Post
I have always used needle-nose pliers to squeeze the clips open enough to slip it further down the hose to remove the hose from the fitting.
JaviNSR
Thu Oct 31, 2013 3:12 pm » Post: #4 » Download Post
And what about the nails.
The don't seem to be hard to squeeze by hand.
TuckerBag
Fri Nov 01, 2013 3:57 am » Post: #5 » Download Post
I rather intensely dislike those clamps as well.
But I just persevere, as is typical with many little things that are cheap and "sort of" functional.
I have never seen a tool for them, but there maybe one out there?
bushman
Fri Nov 01, 2013 8:45 am » Post: #6 » Download Post
TuckerBag wrote:I rather intensely dislike those clamps as well.
A small external circlip pliers does the trick. http://www.knipex.com/index.php?id=1216&L=1&page=group_detail&parentID=1365&groupID=1455
gepe
Sat Nov 02, 2013 9:23 pm » Post: #7 » Download Post
Interesting to see what people come up with to tame these little beasts Wink
I have tried external circlip pliers as recommended but can't get them to work because when you squeeze the pliers, the clip tightens instead of opens. Internal circlip pliers in theory would work but in practice don't because the clip usually is in its open position if the two eyes overlap but this is not possible with the circlip pliers.
I assume that Honda workers on the assembly line neither use their fingernails nor screw drivers to get the clip positioned correctly over a tube. Probably there are some pliers which press on the outside of the eyes and at the same time have something like a slot in each tip which prevents the clip from twisting when being compressed. Yes, and 90° orientation of the tips would be preferable.
Something like this with a slightly different head:
(from: http://blog.toolsource.com/index.php/2010/04/toolsource-exclusive-meritool-hose-clamp-pliers/)
