Hello yesterday i try to start my mc 21 without success.
first i unscrew the spark plugs earth them to the frame to see the spark but there was no spark on both spark plugs. Then I clean the connectors of the two coils and use multimeter to see the ohms
both coils have
0.03 ohm in low tension LT
7.78 ohm in high tension HT
also i check the battery voltage multimeter shows 12.1 voltage when ignition key is OF and kill switch OF
then i turn the ignition key ON and the voltage was down to 10 V and when i press the kill switch to RUN the Voltage was 0 what should i do?
Sorry for my bad english i am from Bulgaria. Thanks for any help
