Wise to remove piston rings to check wear?
gepe
Tue Jan 14, 2014 8:13 pm » Post: #1 » Download Post
Is it wise to remove the piston rings to check their wear? I fear they are no longer round once I have removed them.
greggo
Wed Jan 15, 2014 4:08 am » Post: #2 » Download Post
Are you worried the ring gap is getting too big, or the bore too big?
Either way, rings are cheap(ish) and a new set is good insurance while you have it apart.
Getting a ring off is no worse than getting it on in the first place imho.
Hobbit210
Wed Jan 15, 2014 7:50 am » Post: #3 » Download Post
greggo wrote:Are you worried the ring gap is getting too big, or the bore too big?
Agreed:
but if you do need to remove the rings to re-use then use a thin 'feeler gauge' blade to slide under the ring and move it around the piston lifting the ring from the groove without bending and possibly snapping it.
Mike
