Compression ratio.
simono
Compression ratio.
Mon May 05, 2014 3:21 pm » Post: #1 » Download Post
How exactly do you work out the compression ratio on a two stroke?
I am not expecting a straight forward answer but i am ok with doing the maths unless calculus is involved Laughing
mellorp
Banned
Mon May 05, 2014 5:58 pm » Post: #2 » Download Post
https://www.rbracing-rsr.com/compstaticcalc.html
http://www.csgnetwork.com/compcalc.html
HTH
Thu May 15, 2014 1:48 pm » Post: #3 » Download Post
On a two stroke, I worry more about trapped compression than full stroke compression.
Think about it. Let's say that your NSR has a difference of 1mm of exhaust port height between the two cylinders, but everything else is equal, then the full stroke compression will be the same, but the trapped compression (when the exhaust port closes) will be different.
You need to know:
Head volume
Bore diameter
Stroke (from exhaust port closed to TDC)
When you know these numbers you can use the calculator link
