Bead Blast Dry Clutch
kan3
Tue Apr 22, 2014 2:51 am » Post: #1 » Download Post
Anyone see any issue with bead blasting the outer and inner clutch hubs as well as the pressure plate? Was going to use 80grit bead at 40psi.
Neal
Tue Apr 22, 2014 10:48 am » Post: #2 » Download Post
Blasted my steel plates a few times
Tue Apr 22, 2014 2:42 pm » Post: #3 » Download Post
The basket and hub are hard anodised. I wouldn't recommend it, unless you are happy with possibly removing the anodising, and the probable resulting increase in wear rate.
kan3
Tue Apr 22, 2014 3:52 pm » Post: #4 » Download Post
No problem
I'll just clean it by hand
Thanks
