Timing advance of MC21 flywheel?
gepe
Wed Mar 05, 2014 9:26 pm » Post: #1 » Download Post
Isn't an offset Woodruff Key a 100% substitute for an MC21 flywheel? If so, I would only have to know the ignition advance of the MC21 flywheel compared to the MC28 flywheel.
Does anyone know?
das134
Fri Apr 25, 2014 5:38 am » Post: #2 » Download Post
I also would like to know this. Anyone in the know?
Neal
Fri Apr 25, 2014 7:03 am » Post: #3 » Download Post
4 degrees has been spoken about . Check your jets if you advance your timing
NSR300
das134
Sun Apr 27, 2014 6:33 am » Post: #4 » Download Post
Neal wrote:4 degrees has been spoken about . Check your jets if you advance your timing
4 degrees?? That's heaps, I thought it was closer to 1 or 2... Will definitely be checking the jetting if using the 28 flywheel.
Thu May 15, 2014 1:30 pm » Post: #5 » Download Post
Definitely not 4 degrees!
