Reed block gasket glue?
das134
Tue Aug 12, 2014 8:34 am » Post: #1 » Download Post
Hi everyone, I'm putting my engine back together and want some advice regarding the reed block gasket.
This seems to sit quite 'loose' when fitted. Does anyone glue this in with gasket glue? Or should it always be fitted dry?
I don't want any leaks, but also don't want to do it if it shouldn't be done. Advice much appreciated.
Cheers, Dave
bushman
Wed Aug 13, 2014 12:51 pm » Post: #2 » Download Post
That gasket is a dry fit.Just torque to spec.
kan3
Wed Aug 13, 2014 12:54 pm » Post: #3 » Download Post
Make sure to leak test it anyway. A warped manifold would be more of a concern than the gasket side.
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Mon Aug 18, 2014 1:59 am » Post: #4 » Download Post
It's nice to be able to fit them dry (with just a bit of grease on the gasket), but the insulators (unless brand new) don't seem to be very clever, so best use a bit of sealant on all faces. Best to be a bit messy with no leaks than nice and clean and leaking which will lead to a seizure.
And wise to follow kan3's advice and leak test it.
das134
Mon Aug 18, 2014 10:01 am » Post: #5 » Download Post
Matt@TYGA wrote:It's nice to be able to fit them dry (with just a bit of grease on the gasket), but the insulators (unless brand new) don't seem to be very clever, so best use a bit of sealant on all faces. Best to be a bit messy with no leaks than nice and clean and leaking which will lead to a seizure.
Thanks guys. Matt, what sealant would you recommend for this job?
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Mon Aug 18, 2014 11:32 am » Post: #6 » Download Post
I only use Threebond 1207B on my race engines. It's the best there is for this job and it's what HRC use. High viscosity so easy to apply and copes with high temps. Its an RTV silicone based sealant.
Others I've used:
1104 - Synthetic rubber. Dangerous apparently and now production stopped. low viscosity, so messy stuff to use. I hate it, but many swear by it. Usually find more inside the cases than you actually put on in the first place. It's resistant to pretty much everything used in an engine. It's horrid. If you use this then you will spend more time cleaning it up than actually doing anything enjoyable.
1194 - Synthetic rubber. Replaces 1104. Haven't actually used this but put thought I'd mention it. I'm sure it's as nasty as 1104 but without the lead!
1211, 1212 - RTV Silicone based. 1212 has a higher viscosity than 1211, but other than that they're the same. Corrodes copper (1207 doesn't) so beware what you put it on.
Permatex Motoseal 1 - Possibly a sneaky copy of 1104/1194.
All these will work. But go for the 1207B if you can. You'll wince at the extra cost, but can be assured of top performance.
