Hi all,
I've got Tyga pipes on my MC28. I've cracked the weld on the mount on both pipes and had to re-weld them. If you run the Tyga tail, then you can buy hangers for the cans from Tyga. Nothing seems to be available if you run the stock sub frame. I had some hangers designed and made up in Aus using a water jet. I think they turned out pretty well (photos attached). The guy has the design on file if anyone else is interested.
