MC18 oil pump solenoid, how work it?
panchonsr
Thu Mar 26, 2015 3:54 am » Post: #1 » Download Post
hello friends i have a nsr 250 mc18 and need to know how work especificly oil pump solenoid......when is ON and when is OFF..help me pleasee!!....see you. Very Happy Very Happy Very Happy Very Happy Very Happy
bushman
Re: MC18 oil pump solenoid, how work it?
Thu Mar 26, 2015 1:22 pm » Post: #2 » Download Post
panchonsr wrote:hello friends i have a nsr 250 mc18 and need to know how work especificly oil pump solenoid......when is ON and when is OFF..help me pleasee!!....see you. Very Happy Very Happy Very Happy Very Happy Very Happy
According to the manual,the soleniod current is switched off at 7000rpm,allowing the pump stroke to increase by retracting the pin off the drive,similar principle as variable valve timing.
panchonsr
Sun Mar 29, 2015 8:46 pm » Post: #3 » Download Post
ok bushman, when I get over 7000 rpm valve is switched off ... right? .... so then when you start ignition, the valve should start immediately ... is that correct?....because when i start ignition on, my solenoid valve is no activated....however, the valve is in good conditions....something is wrong....:/
bushman
Mon Mar 30, 2015 5:31 am » Post: #4 » Download Post
Check for electrical continuity on that circuit,there is a wiring diagram in the "Workshop area".
