Hello all ..
After a bit of help with rear brake bleeding ??
Trying to bleed the brakes through no matter what I try I can't get fluid through have checked the seals they look good .. The cylinder seems in good nick the main hole is clear from the res but will not draw fluid ??
To make it worse I got fluid on my nice newly painted exhaust !!
Any help appreciated or if anyone has a good secondhand 21 cylinder I will replace ..
Cheers Paul
