Ignition coil primary voltage MC16
Andylad
Wed Aug 26, 2015 9:10 am » Post: #1 » Download Post
Hello, does anyone know what sort of voltage you should have on the primary side of the ignition coil? This is obviously fairly low coming from the CDI where i assume it has been rectified from D/C to A/C current from the battery? It seems CDIs are a bit flakey on these old bikes. Any comments welcome, thanks.
