Pulse generator output
Andylad
Wed Aug 26, 2015 9:20 pm » Post: #1 » Download Post
Can anyone tell me what voltage the pulse generators should be sending to the CDI on a MC16? Cant seem to find any info for them, thanks.
Andylad
Sat Aug 29, 2015 7:48 pm » Post: #2 » Download Post
Just in case anyone out there is having ignition issues, i tested the resistance on my pulse coils and they were both in spec. However i have heard that sometimes when the winding breaks the resistance can be virtually unchanged but the output is. So after buying a set of used pulsers just to rule that out before shelling out on two new CDIs, i wired them up and problem solved. The resistance readings between the bad coils and the good were virtually identical. Strange stuff electricity.
