Mc21 fork rebuild questions
drunkn munky
Fri Sep 04, 2015 8:41 am » Post: #1 » Download Post
Whats the correct setting for the damper rod adjuster nut as pictured below?
Sun Sep 06, 2015 6:08 pm » Post: #2 » Download Post
I personally set them at either 10 or 12mm from the top depending what damper rod is fitted. You should have an even 12-16 clicks of adjustment on each leg.
drunkn munky
Mon Sep 07, 2015 5:06 pm » Post: #3 » Download Post
Thanks stephen
