In the process of replacing my swingarm bearings. I've noticed the Honda OEM bearings come pre-packed with grease.
Just wondering what the general consensus is...do you normally install with the OEM grease? or repack with a better quality one?
One thing to keep in mind is, I am told, some bearings come with grease that is only intended to keep the bearings from rusting while in their packaging. I am told this grease is supposed to be removed and the bearings repacked with proper grease. Not sure about Honda swingarm bearings, but I'm sure someone will speak up.
