Time to refresh my MC18 2J
Mon Dec 28, 2015 6:18 pm » Post: #1 » Download Post
It's been a few years since my last refresh. Everything is running ok but I thought it was time to sort out a few things.
The exhausts have had a soak in drain cleaner. I'm sending them off to Zircotec to get them ceramic coated
Mon Dec 28, 2015 6:36 pm » Post: #2 » Download Post
Pics Rob, Pics, we need piccies !!!.
Mon Jan 18, 2016 1:54 pm » Post: #3 » Download Post
I took a pair of fairing hinges off to be replicated in titanium. I'm not sure what material they are no because they clean up well and only have a small amount of corrosion. They are held in place with alloy rivets, which had corroded and had gotten fairly soft
The heat shield has seen better days. It will be replaced by Zircotec heat shield which is very thin
This is the difference between the thin Zircotec and another brand
My exhausts after a decoke with Robert Dyas industrial drain cleaner
This is the matt black ceramic coating
sami1
Tue Feb 16, 2016 8:06 am » Post: #4 » Download Post
Hi, how much is the heat sheald from zirotec? what size roughly? thanks
Sat Feb 20, 2016 2:03 pm » Post: #5 » Download Post
A 450 x 550mm sheet should do both sides and is around £50. I comes as a self adhesive. There are 3 options of thickness. I went for the thinnest as I had my exhausts coated by them as well, which cost around £350
Sat Feb 20, 2016 4:41 pm » Post: #6 » Download Post
Proper job!
Fri Feb 26, 2016 9:04 pm » Post: #7 » Download Post
Just picked up the set of titanium barrel & head studs. Very pleased. Perfect copies of the originals
Also picked up stainless duplicated fairing hinges, which are superb. They look exactly the same but not corroded. Will post some pictures later
Fri Jan 20, 2017 12:03 pm » Post: #8 » Download Post
Slow progress
Latest progress
Mon Oct 16, 2017 7:52 pm » Post: #9 » Download Post
Cleaned frame
Powder coated subframe
Tapered head bearings fitted
Wed Oct 25, 2017 6:56 pm » Post: #10 » Download Post
Powder coated forks. Rebuilt with new bushes & seals. Coated with Nyalic. Unfortunately I did seal in a few grease marks.
Sun Nov 12, 2017 6:13 pm » Post: #11 » Download Post
Nice job Rob
Sun Nov 12, 2017 6:17 pm » Post: #12 » Download Post
Hi Rob Nice job always was pretty little bike but it will look like new when completed,
Goodluck Rob
All the best
jonmac
Mon Nov 20, 2017 10:13 am » Post: #13 » Download Post
Chassis is looking great! Smile
Tue Dec 05, 2017 9:46 pm » Post: #14 » Download Post
New front master cylinder hose and clips
Just the job Rob
Tue Dec 05, 2017 10:07 pm » Post: #15 » Download Post
Hi Rob
Where did that come from ? I am fed up with sweaty brake hoses,
Oh and Rob your bike deserves a new reservoir they are only a score OEM, get one bought,
Looking good,
All the best,
jonmac
