Mc21 spark plug wire question
scb67
1981 Yamaha RD350LC
    Send private message View user's profile Yahoo Messenger
Sun Mar 13, 2016 7:13 pm » Post: #1 » Download Post
Hey guys, I have VHM heads on my Performance Engineering rebuild/tuned motor and now the front lower spark plug wire won't reach (I have the rs250 short plug setup to and still to short). I can remove the plug cap from one end of the wire easily but can't remove the end from the coil. I'm afraid of destroying it if I try to hard. Can it be removed?
Are there there any performance coils available to improve spark over the stock coils?
I saw a Uotani high performance ignition kit on flebay.......
"If your not first, your last!" Ricky Bobby
ericandchi
Mon Mar 14, 2016 2:25 am » Post: #2 » Download Post
I use dynatek coils. I would go as far as saying they are better than hrc coils since they are a bit more modern.
scb67
1981 Yamaha RD350LC
Mon Mar 14, 2016 2:35 am » Post: #3 » Download Post
Thanks!! Which model Dynatek coils?
ericandchi
Mon Mar 14, 2016 2:39 am » Post: #4 » Download Post
Miniature series with single output 0.5 ohms. You will need to fabricate some brackets and build your own plug wires. PM me with and I can send you some pics of where I mounted them.
