MC21SP swapping back from NC30 forks etc
messer
Sat Jul 16, 2016 6:52 am » Post: #1 » Download Post
My mc21SP has been fitted with NC30 forks, calipers and discs running on the magtek front. I wanted to swap back to normal SP spec.
Just wondering what I'm going to need, what is the reason for this upgrade are the forks and calipers better or something?
Will fork tubes be larger diameter on the nc30 forks and meaning I will also need a set of yokes too?
Thanks
Sat Jul 16, 2016 11:47 am » Post: #2 » Download Post
NC30 has larger discs. The NC30 calipers will work with the NSR discs. The NSR and NC30 forks are the same diameter, so you won't need new triples.
In summary, you should just need NSR forks and discs... and front fender. (As far as I'm aware, the wheel spacers should be interchangeable too.)
messer
Sat Jul 16, 2016 4:01 pm » Post: #3 » Download Post
Ok that's good news. What is the reason that people do this swap? Anyone want to swap back Smile
